‎2008-07-18 10:10 AM
‎2008-07-18 12:40 PM
schagemann wrote:Mesh 3D.
would it not be great if one could assign a thickness to any given mesh thus making the rather awkward mesh to roof tool redundant altogether?
‎2008-07-19 03:14 PM
‎2008-07-19 10:33 PM
schagemann wrote:May be because the problem is far more complex than it seems at a first appoach.
am i the only one wondering why graphisoft have not yet used this as inspiration to improve their mesh tool?
‎2008-07-21 01:14 AM
Olivier wrote:well, i agree mathematically it is a complex problem.schagemann wrote:May be because the problem is far more complex than it seems at a first appoach.
A vertical extrusion should not be too difficult, but a perpendicular one could be.
Olivier wrote:completely agree - yet again the question can be asked why archicad users need to start coding solutions to such problems in GDL in the first place.
Looking at Petri's object, you quiclky realise some limitations.
1 - because it is an object, not a tool.
2 - because some tiny math calc errors.
Despite these imperfections, it's a very good attempt.
Olivier wrote:yes, in deed all the cudos to petri - neither have i seen such a complex GDL object before.
Petri's math skill is very impressive, i just can say congrats.
Never seen such a complex object. If you know one, please tell me.
Olivier wrote:yes, very unfortunate.
Unfortunatelly, after posting two objects, the guy disapeared.
Olivier wrote:presumably you mean perpendicular, since the mesh-to-roof tool already does vertical... to some extent.
Not asking for the moon, i wish GS could add a vertical extrusion to the mesh tool.
‎2008-07-21 01:22 AM
‎2008-07-21 01:48 AM
‎2008-07-21 02:26 AM
‎2008-07-21 03:11 AM
Olivier wrote:Oleg Shmidt's curtain objects are mathematically impressive. Generating the parametrically adjustable (and very realistic) cloth folds is just incredible.
‎2008-07-21 03:25 AM
Peter wrote:You are right. I mis-remembered myself.
Hello Dwight,
I just did an experiment using the Mesh to Roof add-on because
I remembered there was an issue with the thick
