newly installed AC 12 crashes shortly after opening
I've just installed AC12 and it keeps to crash.
I have a suspicion that it is something to do with the 3D window.
What do you think, is it some kind of incompatibility?
No idea where I shall start to look for the solution.
My computer:
Dell Optiplex GX280
Intel Pentium4 3GHz
Intel 82915G/GV/910GL
Windows XP
Bobita
5 Replies 5
Djordje
My computer:
Dell Optiplex GX280
Intel Pentium4 3GHz
Windows XP
Bobita
RAM?
Your video card is not really suitable for Archicad at all ... so that would explain the 3D crashes.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Cheers!
1.5GB RAM. Not much I guess.
Additional info that there is an AC11 also installed on that computer. Can it cause problems?
Do you have any advise where I can learn something about the compatibility of the video card, etc.?
Bobita
David Maudlin
Look near the bottom of this page for "Video Card Database":
ArchiCAD Talk :: Index
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David, thanks for the compatibility page link.
Eeeeer... Friday was my last day in the office where I worked on this computer.
But you're absolutely right, I will do my profile properly.
Bobita
Make sure your DirectX is updated and all the drivers are updated.
I have ten GX 280's.
Running with half a gig of RAM.
And the CPU is 2.8.
One did the same thing and I updated DirectX and a driver from Intel.
Goto the RUN Command prompt.
Type in DXDIAG you should be running DirectX 9.0.
There is a way to run DirectX 10 on XP, but I am not sure if actually works?
Hope this helps...
By the way I am getting ready for a video card, what video card do you think would be a good one?
I am running AutoCAD 2009, Google SketchUP 7 and PTC Wildfire 4.0.
Thanks...
