open GL problem!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-11-05 06:45 PM
I have problem with open GL in 3d window, it's black! 😕
The 3d window in archicad goes black when i press F5. I can only see the objects when i move and rotate the screen. I can't model in 3d wondow. I've tried to change some open Gl settings but nothing happens.
Please help..
Thanks.
- Labels:
Performance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-13 08:48 PM
If the problem is solved, then it might be graphical, otherwise something else (System/ OS /ArchiCAD)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-13 09:21 PM
i've tried to reinstall the archicad, still same problem.. how can i check if the windows is causing the problem? i can't reinstall it now, i have lot of work for the school.. any more ideas?
thanks for the replies
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-17 04:42 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-18 11:43 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-18 01:23 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-18 02:29 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-18 03:06 PM
strale88 wrote:I used to have a problem like this with ghost lines sometimes cropping up when I stopped panning/rotating - this was a couple of years ago. Somewhere along the way I must have done a driver update because it hasn't happened of late.
when i rotate, drag in the screen, it doesn't have any problem or going slow, just when i stop moving, the 3d window goes black..
At that time pressing F5 again (while in the 3D window) used to clear the lines and show the correct picture.
Also as Joeri says in another thread
...maybe you can start investigating your graphic card performance.300
View > 3D View Mode > 3D Windows Settings > 3D Engine : turn off OpenGL and try Internal Engine...
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-19 09:43 AM
i've done all possible updates of all my drivers installed..
and i also tried the Internal Engine in 3d. in the begining its running fine, but while i fill my project with more objects, its going slower and slower, and the 3d model isn't clear when i am exploring it..
i know the 3d window can be viewed with internal engine and opengl, but is there maybe some way i can use direct x to view my 3d? 😕
thanks..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-19 10:07 AM
Many motherboards have on-board graphics which may not be very good but would confirm if it's your graphics card that's at fault. Alternatively can you borrow a friend's graphics card for a few hours?
bT Square Peg
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-20 01:53 AM
Does it do the same things on different versions of ArchiCAD?
