Installation & update
open GL problem!
Hi.
I have problem with open GL in 3d window, it's black! 😕
The 3d window in archicad goes black when i press F5. I can only see the objects when i move and rotate the screen. I can't model in 3d wondow. I've tried to change some open Gl settings but nothing happens.
Please help..
Thanks.
23 REPLIES 23
i've tried more versions but the problem is same. i do not want to change graphic card because only the archicad 3d window is black and all other 3d application work perfectly with opengl and directx..
You can try installing earlier versions of the graphics card driver until you find one that works.
It is possible to find earlier versions.
XP:
http://support.amd.com/us/gpudownload/windows/previous/Pages/radeonaiw_xp.aspx
Vista:
http://downloads.guru3d.com/Videocards---ATI-Catalyst-Windows-Vista_c31.html
i have allready tried that, doesn't work.. 😕
i can see the model in internal 3d but it goes very slow. is there any way to make it go faster or something..?
We've had the same problem in Windows Vista. The solution was:
Activate XP-Compatibility for Launching ArchiCad
Right Mouesclick on archicad.exe -> Compatibility-> WindowsXP(ServicePack2)
