plotmaker won't update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-04-26 12:10 AM
Is this because I'm using the two different versions? Or is it a Windows XP issue? Any help would be appreciated.
- Labels:
Performance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-04-26 12:41 AM
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-04-26 01:44 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-04-26 02:03 AM
It is simple to make a PMK. As soon as you have a plan or other view that is ready to publish just save it as a PMK file. Name it appropriately and put in a place you can find it from Plotmaker. When you open plotmaker just import the PMK file and place it in the sheet as you would any other view. The PMK file does not update automatically. When you make changes in ArchiCAD you will need to resave it overtop of the original PMK and then update it in Plotmaker. Hope this helps.
Perhaps someone else knows why you are getting this error message.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-04-26 05:06 AM
Check with your reseller - as 10 is lurking around the corner, there is probably some kind of special for the upgrades now.
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-04-26 02:42 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-11 03:57 AM
all i want to do is update my plotmaker files in 9 and it says it cannot find the archicad 9 path..
i've tried reinstalling but doesn't fix.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-11 05:08 AM
dbroughton wrote:What components? It is very possible that you are not finding what you need.
well i have the same problem and i'm using PMK 9 and archicad 9.... i have used version 10 but it is missing some important components so i cannot use it.
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-11 05:25 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-01 07:23 PM
What raises further suspicion is that it succeeds on one computer, and fails on another, identical machine. It leads me to believe that there is an installation/update/re-install sequence, depending upon the key, upgrade or new license, etc. which is causing the issue. No answer yet, but maybe some different thinking will help the process.
Thanks!
