Installation & update
plotting blank pages for one file only
Greetings,
On one file publishing or plotting any of the pages causes a blank page to print. It is not even plotting out the title block. I have created new files both in archicad and plotmaker, copying info from the old drawing, and the problem continues into the new file.
Any suggestions about how to fix this file, or any steps to troubleshoot this file would be greatly appreciated.
Thank you.
Sky
1 REPLY 1
Djordje
After you write your OS and Archicad version in your signature, set up your PlotMaker template sheet sizes according to your output device and all will be well.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
