"Not enough memory to complete the operation"
We are having this message when trying to open a LBK (99,285kb file size). How can I fix it?
7 Replies 7
TomWaltz
What happens after the error? Does Plotmaker have the file open? Does it crash?
Tom Waltz
TomWaltz
Is the error message actually causing a problem, then? Or is it just annoying that it pops up? Can you open sheets, plot, etc?
Tom Waltz
It plot perfect, I can open different sheets but the .plt are not shown and the pop up is annoying. Looks that you know what happened!
Working around we decide to split the LBK. One for architecture, and one for every consultant. We used to import the consultants plans as .plt in the LBK. Is there a maximum size for those plt to work fine with PlotMaker?
TomWaltz
Actually, I have no idea. I was just trying to narrow it down to what it might be. I've seen that error before, but usually when copying/pasting between sheets.
Tom Waltz
Thanks anyway, I hope someone could find what cause this error.
