2004-01-06 12:42 AM
2004-01-08 11:15 AM
Karl wrote:Wow all this seems well thought, nothing like this in VNC !😉 Yes, it is by invitation only. Under System Properties (right mouse My Computer), Remote tab, you can disable Remote Assistance altogether. Otherwise, you are able to send an encrypted invitation via email to someone - an invitation with a specific expiration period in fact (1 hour, etc.)
Karl wrote:I read somewhere, but can't find it back, that there was a hidden user account (login name made of several letters and numbers) that could represent a security problem, unless you completely disable the service (this mean putting it in "disabled" stratup mode, manual is not enough)... Am I paranoïd ?
Of course, this being a Microsoft product, there are probably huge security flawssomewhere!
2004-01-08 03:41 PM
So...I'm with you! WHY can't ArchiCAD run from remote desktop? The error message is wrong anyway - ArchiCAD wouldn't be running on the client - it would be running on the host. The client is only viewing the host desktop.This makes no sense!!!
2004-01-08 04:17 PM
Red wrote:Is it usable ?
I got it to work last night with remote desktop. I started Archicad on the host and then remotely connected to it from another desktop.
2004-01-08 05:39 PM
2004-01-08 08:01 PM
Geoffroy wrote:You might be referring to the Guest account. This is a huge security hole. In peer-to-peer XP networks, the Guest account is what allows others to see shared folders/files on your machine. It is normally disabled from the login screen, but can be seen from the Control Panel, User Settings area.
2004-01-09 07:17 AM
Red wrote:I missed your message and just discovered the same thing! Will report the issue to GS - makes no sense that if AC is already running, we can connect to it with remote desktop, but if it isn't running, it will not allow itself to be launched.
2004-01-09 02:42 PM
Karl wrote:There is still another one, I think XP Antispy can remove it... AFAIK, it's a hidden account reserved for Microsoft remote maintenance...
Well... even if that isn't what you were thinking of, a good tip for anyone running XP.
