Installation & update
saving an IFC
in archicad14 when i click save as and select IFC 2X3 the 'Export' pull down is blank and the 'Translator' pull down lists only 'general translator'. i am fully updated, libraries and all....help!
5 REPLIES 5
Steve Jepson
Have you tried to access the Translator using File Special or just Save as ?
Did you notice that we have very limited IFC Model Units. I need Cubic Yards ! Square Yards, etc....
I have the same complaint about ArchiCAD units available for use in schedules.
WE NEED MORE UNITS OF MEASURE ! Is that so hard to do?
i can go through File Special and looks like I can choose structure or HVAC but there are still no other translators but 'General'. Also, not real sure if making that selection registers anywhere??
Steve Jepson
hmm...Menu should look something like this
i have only the General Translator where you have several other defaults for different data exchanges, i would screen shot, but it just crashed for the 3rd straight time. it crashes anytime i mess with that dialogue box...i think i might go to hand drafting
got it.... its read and write privileges on my machine causing the issues
