Installation & update
switching from revit to archicad
hi, i'm new to archicad... kinda. i used version 6 ages ago but have been using revit since 2006. i thought it would be a piece of cake getting back into archicad but find i'm mistaken. i've done the basic interactive training but have difficulty doing the exercises on my own. could be because i'm trying the same approach as in revit, which doesn't work, obviously.
anyone here made the switch? any tips on how to un-revit my thinking?
117 REPLIES 117
Thomas Holm
Interesting subject. I haven't used Revit. I would say do all the basic tutorials you can find, and try to get the knack on the workflow there. Of course there's a risk you might get bored and start jumping steps, since you're a seasoned CAD user.
I personally start modeling in the floor plan (in most cases), use the 3D window for checking, then create sections and elevations and perhaps 3D views as well.
I try to use a template's layer combinations from the beginning.
When the model starts to get advanced enough, I start to save views (use the view map in the Navigator). Then I create one or more master layouts, and then open the Organizer and place saved views on the layouts. Then i use the Organizer again and create publisher sets and include layouts in them using the create shortcut button.
I guess some people with more Revit experience can help you better.
Matthew L? Tom W?
David Larrew
I have a feeling that you are not alone (at least, will not be alone in the near future). I am directly hearing a growing dissatisfaction with Revit users who are struggling to make the switch to "BIM". Unfortunately, the users that are suffering with the software are not the ones that Autodesk has convinced that Revit is the right solution. This is why GS really needs to get a great marketing campaign going... But that is another thread.
In the end, software is a tool just like a pencil and paper. Once you learn the basics on how to use the tool, as long as the tool works, you will be able to utilize the tool to do your job.
As I tell any new user of ArchiCAD when they are first starting out... Forget everything that you know about your old CAD package, and don't fall-back on your old "reliable" way of doing things. Yes, it is painful to learn something new, but AC is really easy to get productive quickly.
Good luck, and welcome back to the "light" side.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
TomWaltz
I doubt they'll be much happier on Archicad. Right now, we get to see two products with different development histories providing very similar user frustrations: A lot of workarounds to achieve the something resembling the promises the vendor makes in their marketing material.
I've been hearing "my brother's roommate's cousin" stories about Revit and how bad it is almost from the day it hit the market. It's funny how they mostly occur on Archicad (or other competitor's) sites and not so much on the Revit ones.
Every software has stories about people who could and could not make it work. It's the stories about the people who succeeded that interest me a lot more than the stories about those who could not.
Tom Waltz
Thomas Holm
greenfin wrote:
... any tips on how to un-revit my thinking?
Can we get back to the subject of this thread, please? greenfin asked for practical advice, not general views on why or why not?
when i first used archicad back in 2000 (version 6) i had no problem learning it. i had no previous BIM experience back then so maybe that helped in that i had no preconceived ideas about how it worked. (i'd been using autocad but that's a completely different matter.) change of employment led me back to autocad until another introduced me to revit. learning revit wasn't a problem either, it just felt more intuitive somehow. another move will bring me to archicad country, hence the need to switch back. but either archicad has changed so much since version 6 or my brain has been completely altered from revit use or as i get older learning new things or even re-learning them gets harder.
is there an 'archicad for dummies' out there? would any of the ff be any good in my case?
'ArchiCAD: Best Practice: the Virtual Building Revealed'
'Training Guide for Archicad 11: Step By Step' by Simmons
Thomas Holm
I suppose you have worked through all these: http://www.graphisoft.com/products/archicad/ac11/ITG/
and http://www.archicad.ca/ is excellent. Google is your friend!
Chazz
Thanks Thomas. Speaking as an occasional (some might say incorrigible) thread hijacker, this is an especially juicy topic to hijack. Everyone has an opinion.
The very best aid to learning ArchiCAD is not the tutorial or the DVD (though both can be helpful). In fact, the best learning aid for ArchiCAD also happens to be the best for Revit. The best learning aid is...... a deadline.
The truth is that it's hard to get fired up about someone else's tutorial exercise but there is no motivation on earth like a client and a deadline. Take it for granted that your first project will be an acid party in terms of process and product so you have to just get over your perfectionism but it is these mini fiascos that fuel your desire to do it right in future. As my touchy-feely professor at the U of California said "transformation only comes when you want it like that next breath of oxygen." To greenfin beta I say go for it.
Nattering nabob of negativism
Thomas Holm
I'd like to add that a day or two of hands-on training by a professional Archicad trainer is probably worth it's cost several times over. YOu know the small time-savers "do it in this order" etc.
And Chazz, I think it's time you change your signature! There are others that aspire for the negativity throne...
Chazz
Thomas wrote:
I'd like to add that a day or two of hands-on training by a professional Archicad trainer is probably worth it's cost several times over. You know the small time-savers "do it in this order" etc..
When I train, I request that users have a real project to work on (again with a real deadline) and that they have begun some work on it. The best approach in my experience seems to be 4 hour session (max) with the student banging his head on the project solo for the rest of the day. I suggest that they keep a clipboard with them to log questions. Doing that a few times per week is an effective regime, IMHO.
But Karl or Tom Waltz or Matthew or James or someone summed it up best when they said training makes no difference at all if the student only sees that ArchiCAD is different/harder/lamer than his/her last CAD tool. Attitude is everything. You need to want it like that next breath of oxygen.
Learn and get certified!
