twiggy_4ever
the file does not open
Здравствуйте, файл вообще не открывается. Пишет, что план не может быть прочитан. Файл также не управляется через AutoCAD. Что вы думаете? Могу ли я что-нибудь сделать или мне просто смириться с потерей?
Я не могу прикрепить файл сюда, он слишком большой.
Hello, the file does not open at all. He writes that the plan cannot be read. The file is also not managed via AutoCAD. What do you think? Is there anything I can do or should I just accept the loss?
I can't attach the file here, it's too big.
3 Replies 3
Eduardo Rolon
Please post in English,
There is not enough information to figure out your question.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
What kind of file is it? DWG or PLN/PLA? AutoCAD will not be able to read PLN/PLA files since they are Archicad's native file format.
If you try to open a PLN/PLA file, what happens if you check the "Open and Repair selected file" in the Open Dialog when you try to open the file?
Ricardo Lopez
Hi @twiggy_4ever
I don't fully understand your question, but you can read this article on "Cannot read Plan file" which might help you: https://support.graphisoft.com/hc/en-us/articles/29967874212241-Cannot-read-Plan-file
Ricardo López, M. Arch.
