VILMAMARTINKOVA
top toolbar
please help i accidentally
deleted my top toolbar and my 3D window.. how do i get them back?
1 Reply 1
Marc H
It appears you ‘deleted’ (really just closed) your Standard toolbar.  You can go to Window>Toolbars>and select Standard.  And/or, if you want to customize or return to AC defaults, you can go Options>Work Environment>Apply Profile>Architectural (or MEP Engineering…), or go into Work Environment and customize a new one.
As to the 3D Window, you can right-click in the 2D window and select Show All in 3D.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
