wibu key not found
I currently had archicad version 10 and 12 installed on the computer. I wanted to work on an older file and reinstalled version 7 r2. Now I cannot access any archicad files. The system tells me wibu key not found. Please advise.
I have tried to go back to the upgrade key webpage, but it gives me an error when i try.
Thanks,
Matt
2 Replies 2
Eduardo Rolon
Reinstall the WIBU drivers it could be that AC07 overwrote something. You could do a custom install of 12 or check in archicad wiki.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Just download the current driver here:
http://www.graphisoft.com/support/archicad/downloads/WIBU.html
and install. Should take care of it.
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
