Installation & update
Installing or updating your app. Hardware/software requirements, OS specs.
zoom problem: it zooms another point
Zoom Problem: I have to click “to previous zoom” when going from one floor to another. Because it zooms another point in other plans. For example; a column is zoomed in ground floor, when I go to first floor, it zooms another place and I click “to previous zoom”, wait and see same column after these steps.
Is there anyone know how to solve this problem?
1 REPLY 1
Are you going from storey to storey using saved views in Navigator? Or just going up a storey / down a storey?
If using saved views, it will go to the viewpoint saved in that view.
If you are going up and down with the Up a storey / down a storey command (CMD-Up Arrow or Down Arrow) then the viewpoint should remain the same.
