2 separate objects have the same GUID?
JGoode
I have 2 separate objects but they both have the same GUID somehow which is making migrating a nightmare. Is there any fix for this besides doing a save-as so the guid changes?
Thanks
ArchiCAD 27
Windows 10
runxel
Hero
I think this might be already actually the quickest solution.
You could also convert it the gsm to XML and then change the GUID by yourself...
Nader Belal
Mentor
Easier solution in 2.5 steps:
Step 1: Select one object of your liking and open it in the GDL Editor
Step 2: Save it in any location of your liking (saving it in the same place with the same name will just do it)
Step 2.5: Make sure to click on "Create New Library Part" as seen in the picture below.
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
