2d symbol versus 2d view output
Michael
Please see library object 2d views and symbols attached question
Michael |:-)
AC 4.5 - 19 Build 3003 Full USA
Mac OSX 10.10
6 REPLIES 6
Michael
Text on object imported from sketch-up, with no visible means to delete, see screenshot
Michael |:-)
Mac OSX 10.10
Michael
"Help," the man says
Michael |:-)
Mac OSX 10.10
alemanda
You can open the object and edit graphically the 2D symbol skipping the 2D gdl Text. There's an option "add to 2D symbol" some where in the libray part editor.
Hope it helps
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Michael
Well I can not locate this command in AC 18 library part editor … this is such a common issue I am sure there is an "how to" link somewhere, I started on the Forum first.
Thanks to your suggestion Alemanda
Michael |:-)
Mac OSX 10.10
David Maudlin
Michael:
If there is any code in the 2D Script window, then ArchiCAD will read that script and ignore the 2D Symbol Window (unless the 2D Script calls elements from the 2D Symbol window). Go to the 2D Script window and either delete the script, or Comment (adds a "!" in front of each line of script) so the script is not read.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Michael
David:
Appreciate your comment.
Very helpful.
As well I received this link :
http://www.shoegnome.com/2013/05/30/creating-2d-symbols-for-archicad-objects/
Together both responses have made for an easier start to the work week
Thank you,
Michael |:-)
Mac OSX 10.10
