3D tree object beyond parameters
sarahric
I would like to know why this happens, when I use a tree object from the Archicad library and resize it, the leaves are left floating far from the trunk and branches and well beyond the dimensions given.
For example, I have a tree here that is 850x850mm, and shows this in plan, but in 3D the leaves extend to up to 1500mm from the trunk (so tree is actually 3m in diameter)
Parameters:
density in % 40
resolution of crown 70
Diam of crown 80
res of leaves 10
diam of leaves 50
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
12 REPLIES 12
Erwin Edel
Have you tried ArchiTree BROAD 1.0 from the object depository (sitework > garden)? Maybe it will suit your needs better. http://archicad-talk.graphisoft.com/object_depository.php?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
David Maudlin
sarahric wrote:
How did you go with the actual size of the tree. Is it beyond the size given?
It's a tree, I don't expect precise dimensions (now if it was that way for Columns, different story). You can always decrease the size to get a smaller diameter.
sarahric wrote:
I have a project where I wanted a low small tree (almost a bush, but the bush object is not appropriate) in my 3d rendering right next to the house, but I couldn't make it look right without leaves floating of and inside the house!
Another option is to place the tree/bush on a layer that is visible for the exterior rendering, but hidden for interior views, if you are not showing both at the same time (like with BIMx).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
sarahric
Thanks.
I had started to put 3d trees on a seperate layer, and 2d trees in plan, just because I need the correct width of the tree in plan.
Guess thats it
