2021-07-12
		10:14 PM
		2023-05-24
		10:18 AM
			Rubia Torres
2022-07-28 04:48 PM - edited 2022-07-28 04:55 PM
Dashed lines for shelves behind cabinet door? I am testing AC26 now, but it seems like this function is still missing. This is basically the only reason we are still stuck with pricey 3rd party solutions.
I can set the door to be glass and transparent, then the shelves will show as solid lines, not dashed. (extra issue: I am seeing the side walls also, which I'd like to not see) Probably add some graphic override magic, but last I checked, GO applies rules to the full object not to certain parts of it, so I guess I will have a result with all the lines dashed, even the ones I want to be solid.
It's sad, because they have put a lot of work in this new cabinet tool, but this simple function keeps me from using it.
