Streamline your workflows and master BIM coordination! Program starts April 28.!
AC26 Bug: Can't change layers of light objects
Leandro Paganelli
In Archicad 26 (3003 BRA Solo - Windows), it's not possible to change the light objects' layer in the toolbar. All other type of objects seems to work normally.
10 REPLIES 10
JeffH
It appears  I have the same issue.
Though if I enter the Lamp properties, I was able to change the layer in the Properties dialog box.
AC24 / AC26 / AC27
Win10
Andrii Levko
In AC26 beta version was the same only through Dialog Settings changes the layer of lamps.
Andrii
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
I just tried with AC26 Build 3010 and it works. I was able to change layers for a selected light using the Info Bar.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 27 (user since 3.4, 1991)
16" MacBook Pro; M1 Max (2021), 32GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
Benjamin Dani
Thank you all for highlighting this issue!
This is a new bug which is already entered in our database under DEF-10251.
Until the fix of this problem I suggest using the element setting dialog to change the 'Lamp' objects' layers.
Kind regards,
Dani Benjamin
Technical Support Engineer
Perhaps this is a Windows only problem? Because it works on Archicad 26 on my Mac.
Andrii Levko
Apparently only on Windows,
I checked on Archicad 26 INT FULL 3001 version on Windows yesterday, it does not work, only using the element setting dialog.
Andrii
Huaralsheep
This issue remains in AC 26 3010, is there a solution?
ArleneMills
Is it fixed?
Is it fixed? For a college assignment, I must write an essay, but I don't know what to write about. I searched online for ideas to assist me come up with a theme and found https://letsgradeit.com/review/essaythinker/. This website has provided me with a lot of value.
Sebastian Martinez
I've installed the latest version, AC26 4019, and the bug remains.
