2022-08-04
05:32 PM
2025-01-30
02:18 PM
Aruzhan Ilaikova
In Archicad 26 (3003 BRA Solo - Windows), it's not possible to change the light objects' layer in the toolbar. All other type of objects seems to work normally.
2022-08-04 07:36 PM
It appears I have the same issue.
Though if I enter the Lamp properties, I was able to change the layer in the Properties dialog box.
2022-08-04 09:12 PM
In AC26 beta version was the same only through Dialog Settings changes the layer of lamps.
2022-08-05 10:37 PM
I just tried with AC26 Build 3010 and it works. I was able to change layers for a selected light using the Info Bar.
2022-08-11 09:16 AM
Thank you all for highlighting this issue!
This is a new bug which is already entered in our database under DEF-10251.
Until the fix of this problem I suggest using the element setting dialog to change the 'Lamp' objects' layers.
Kind regards,
Dani Benjamin
Technical Support Engineer
2022-08-11 09:28 AM
Perhaps this is a Windows only problem? Because it works on Archicad 26 on my Mac.
2022-08-11 09:43 AM
Apparently only on Windows,
I checked on Archicad 26 INT FULL 3001 version on Windows yesterday, it does not work, only using the element setting dialog.
2022-09-14 02:07 PM
This issue remains in AC 26 3010, is there a solution?
2022-10-09 01:46 PM
Is it fixed?
2022-10-14 05:32 PM
I've installed the latest version, AC26 4019, and the bug remains.
