AC9: DOOR/WINDOW FILE NOT FOUND SCRIPT ERROR
I HAVE BEGUN A NEW PROJECT FROM AC9 STANDARD TEMPLATE AND AFTER A FEW DAYS OF WORKING THE DOORS AND WINDOWS ARE DISPLAYING "FILE NOT FOUND SCRIPT ERROR AT LINE ***". I HAVE GONE THRU ALL OF THE UPDATING, RELOADING, ETC. TROUBLESHOOTING I AM AWARE OF. THIS IS THE FIRST TIME IN MANY YEARS I HAVE SEEN THIS. CAN ANYONE PROVIDE INSIGHT?
2 Replies 2
pheelan,
Are you sure the error isn't "Fill not found"? If so this has been discussed several times in this forum. A search should supply the answer.
Doug
David Maudlin
pheelan:
If it is fill, then see this thread:
Library Parts Not Working Properly
Also, no need to shout.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
