‎2015-04-11 05:15 AM
‎2015-04-11 03:01 PM
rtaheri wrote:This means the surface does not stay in a single plane. You will need to check the coordinates of all the points.
When using command PLANE, the error comes " Normal vector and edge x is not perpendicular in peon x in elem xxx"
‎2015-04-12 11:51 PM
‎2015-04-13 03:06 PM
rtaheri wrote:That should work, as any 3 points will be in (define) a single plane. Beyond 3 points is when the coordinates need to be calculated to ensure all points are in a single plane.
I will try to make 3 sided PLANEs and see what happens.
‎2015-05-29 09:20 PM
