Add surface to Polygon or Plane
I have written a GDL object. The lines are drawn and GDL script is OK. But there is no fill on the surface.
When I write the 3D script with PGON, the error message comes " Wrong Edge Index at PGON xx".
When using command PLANE, the error comes " Normal vector and edge x is not perpendicular in peon x in elem xxx"
4 REPLIES 4
David Maudlin
This means the surface does not stay in a single plane. You will need to check the coordinates of all the points.
You will get a better response if you explain what you are trying to accomplish.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks a lot David.
I have an object in wireframe, with only lines, using vert and edges. I am trying to add surface fill to the object.
However when make PGONs error comes " Wrong Edge Index at PGON xx".
I tried using PLANE instead and the vector error message appears. I will try to make 3 sided PLANEs and see what happens.
Roya
David Maudlin
That should work, as any 3 points will be in (define) a single plane. Beyond 3 points is when the coordinates need to be calculated to ensure all points are in a single plane.
Thanks a lot David. Your comment helped me solve the problem. You are great. 🙂
