Aligning a repeating texture to repeating elements
TomWaltz
I'm trying to write a tile surround object that would physically model the tiles complete with grout lines.
Part of the goal is to align a photo-real texture to each individual tile (not always the same one, sometimes part of a pattern).
I'm banging my head against it since I am not having much luck aligning the origin inside the object, let alone finding a way to toggle between materials from tile to tile....
Aside from buying ArchiTile, any suggestions?
Tom Waltz
16 REPLIES 16
Djordje
No.
You might want to build a hotrod yourself, but not a daily driver, right?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
It's sometimes cheaper in the long run to build one myself that does exactly what I need/want than buying and maintaining multiple licenses of a 3rd party product.
Tom Waltz
Frank Beister
I do not know if understand you right, but have you tried to allign each tiles origin by VERT, COOR and BODY?
TomWaltz
Tried, yes. Succeded.... no.
I have not had much luck figuring out the relationship and usage of those three commands. I know there are a couple pages in the GDL manual, but I am struggling to make sense of them.
Tom Waltz
Hello Tom,
Do you have the GDL Cookbook 3 ?
DNC has a couple of pages explaining these commands.
Peter Devlin
Frank Beister
Yes, they are described quiet well in the cookbook. Jochen is (hopefully in the moment ) working on the English edit pages of the selfgdl database, that I could translate some of the related parts. You have first to define 4 vertices by VERT. Then you activate them by COOR and close it by BODY to start the next alligning.
The four vertices are
X1/Y1/Z1 of the origin of the texture in space
X2/Y2/Z2 of the X-axis direction
X3/Y3/Z3 of the Y-axis direction
X4/Y4/Z4 of the Z-axis direction
The direction of the axis a viewed by the actual origin 0/0/0.
So the actual origin is
0/0/0
1/0/0
0/1/0
0/0/1
BASE
VERT 0,0,0  ! origin
VERT 1,0,0  ! X
VERT 0,1,0  ! Y
VERT 0,0,1  ! Z
COOR 2,   1,2,3,4
BODY -1
TomWaltz
OK, so those 4 allow you to set the origin and direction... how do you control scale/size?
Tom Waltz
Frank Beister
I haven't proofed, but I think with TEXTURE an a new MATERIAL for each scale.
David Collins
If you have the Cookbook, look at the script for the ArchiDwight object pg 2.155, which uses TEXTURE and MATERIAL to control the size of the bitmap. Also, watch the BODY -1 statements in your script. There should be one just before the script for the target object and another just after the vert/coon statements.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
