2006-10-24 06:21 PM
2006-10-24 06:22 PM
TomWaltz wrote:No.
Aside from buying ArchiTile, any suggestions?
2006-10-24 06:46 PM
Djordje wrote:It's sometimes cheaper in the long run to build one myself that does exactly what I need/want than buying and maintaining multiple licenses of a 3rd party product.
You might want to build a hotrod yourself, but not a daily driver, right?
2006-10-24 07:05 PM
2006-10-24 07:46 PM
F. wrote:Tried, yes. Succeded.... no.
I do not know if understand you right, but have you tried to allign each tiles origin by VERT, COOR and BODY?
2006-10-24 08:34 PM
2006-10-24 09:07 PM
BASE VERT 0,0,0 ! origin VERT 1,0,0 ! X VERT 0,1,0 ! Y VERT 0,0,1 ! Z COOR 2, 1,2,3,4 BODY -1
2006-10-24 09:20 PM
2006-10-24 09:46 PM
2006-10-25 10:12 AM
TomWaltz wrote:If you have the Cookbook, look at the script for the ArchiDwight object pg 2.155, which uses TEXTURE and MATERIAL to control the size of the bitmap. Also, watch the BODY -1 statements in your script. There should be one just before the script for the target object and another just after the vert/coon statements.
OK, so those 4 allow you to set the origin and direction... how do you control scale/size?
