ARCHICAD does not convert AutoCAD 2D elements automatically to 3D you need to model them.
If the Autocad file has a Model then you need to import it as an object to keep its 3D Settings (File-> Library and Objects -> Open Library Part -> External File)
If you already have modeled the facade en ARCHICAD then check that the layers are on in the 3D Window prior to rendering.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08Mac Studio M4 Max 64GB ram, OS X 10.XX latest
