luciant
Archicad 21 new Countertop Element
On page 104 of the Archicad 21 pdf help guide it says there is a Countertop Element in the USA version. Does anybody know where this element is located?
Thanks!
IMac OS X 10.13.5
4 core Intel 3.4 Ghz, 16 GB Ram,
AMD Radeon HD 6970M
Archicad 15, 16, 17, 18, 19, 21, 23
7 Replies 7
Eduardo Rolon
In the object tool search for "countertop" it should pop up in the list. Though it is not a good object to use and I would avoid it. It does not resize from corners and has some other problems.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
luciant
Thanks Eduardo. I found that object and I agree - not very useful. What threw me was that the guide used the term "Element" not "Object".
IMac OS X 10.13.5
AMD Radeon HD 6970M
A bit annoying that this is only available in the USA version
Eduardo Rolon
You don't want it.
AC29 US/INT -> AC08
another Moderator
Why not?
Eduardo Rolon
Read above.
  • • Splash connections can not be 45º.
    • Height to floor is specified to under the cabinet not to top.
    • Missing hotspots (only 2 for the back corners). Only one stretchable HP.
    • Only 2 basins.
    • It is the same as the existing Multi Basin Counter except you can stretch from the corner (which I was wrong to write above)
    • It is more difficult to use than a slab and a regular sink object
    • Distance between sinks is specified from sides of counter not from center.
    • No option for a counter underneath.
    • Taps are centered, no hotspots to move like Multi Basin Object.
    • Only available for US.
Was not worth it to list it as an "Upgrade Object"
AC29 US/INT -> AC08
another Moderator
Sounds like it was an after thought or maybe even an afterbirth
