Friday
- last edited
Tuesday
Anyone using version 28 experiencing the inability to drag and drop a dwg or add it via. file/external content/place external drawing?
When you go the file/ex route and look at the available file formats .dwg is gone.
Operating system used: Windows 28.0.2 USA Version 3110
Solved! Go to Solution.
Tuesday
Hi Laszlo,
I had to do a re-install with a fresh download to get it fixed.
Friday
- last edited
Tuesday
Does not seems to be the same dialog for the place external drawings formats, here is what I get in AC 28.0.2 Mac:
Monday - last edited Monday
Are you using the full commercial versions of Archicad, or the Start/Solo version?
I just looked at my options when I place a drawing and I see this.
Tuesday
If you go to the Options > Add-On Manager Dialog, do you see the DWG/DXF Input/Output Add-On listed?
Is there a checkmark next to its name in the Load column? That indicates that the Add-On is loaded into Archicad properly.
Tuesday
Hi Laszlo,
Tuesday
OK, great, so it was resolved.
