Automatic dimension annotation to windows in schedules
Can anyone (GS please?) tell me what needs to be added to the window (and door) objects so that they can have the automatic dimension annotation added in the schedules on version 13?
In the diagram below I have three standard GS windows.
The storefront is from the library shipped with Archicad.
The other two are from the AUS Essential library.
Only the "Nominal size" option shows any dimensions at all but not in one window.
You can also see it also show in the 3D view for one window.
None of the other options - wallhole size, reveal size, unit size, etc. - work at all.
I am sure I have seen the wallhole size work on some other objects.
I know it is not the hotspots as I have scripted those out and the dims still work.
Commenting out various pieces of the frame in 3D script makes the dimensions disappear and then uncommenting them brings the dims back.
But all the windows have sripts for the frame (obviously) and they are all based on the overall "A" & "B" sizes (nominal sizes) so I can't spot any difference.
The scripts also have "wallhole" commands in them but they won't dimension.
I know we can annotate mannually but I would rather not have to.
Can anyone shed any light on this please?
Thanks,
11 REPLIES 11
ztaskai
Graphisoft Alumni
Ben wrote:
Maybe automatic dimensioning info should also be mentioned in the new features of GDL page as well.
Yes, sure. It wasn't added as this is not strictly a GDL feature - it is not a change in the language itself. I guess it is worth a mention though. I updated the file; it should appear in a few minutes.
Thanks for the suggestion - and for the comments on the docs:)
Regards,
Zsolt
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
I have a question regarding this. When you set a door height to lets say 204 (which is a clean opening on a finished floor) the door's threshold is on the floor as it should be but in order for this to happen you have to set a sill height with the same dimensions as the floor thickness. But the wallhole size has to be without a sill when being constructed because no ona will construct a wall (like shown in the section) under the door. I know that I can make this go away with SEO but thats not the point the marker is showing wrong dimension for the construction sheets. Can I make the door size minus the floor thickness? i.e different wallhole and different egress size.
undefined
