Project data & BIM
SOLVED!
how to reduce the door dimension font in the door schedule
mrsneuna
How to reduce the door dimension font in the door schedule without having to open the annotations one by one
1 ACCEPTED SOLUTION
Solution
You can go into the 'annotate' mode and edit each separately.
Or just choose the size you want in the dimension settings, and turn off the automatic annotation and turn it back on again to re-do the dimensions.
2 REPLIES 2
Solution
thank you its work
