‎2014-08-21 06:58 PM
‎2014-08-27 02:00 PM
rob2218 wrote:you would have to make gdl code edits to the cabinet and or the base macro for the cabinet. otherwise you are stuck with seo to accomlish this.
here's the deal.
we need to have two cabinet objects back to back but...we need the back panel of the object to have an 'open' back. Meaning we need to see thru the cabinet object.
how would you accomplish this WITHOUT using "operators" such as slabs that you place on hidden layers...?
thanks,
‎2014-08-27 02:31 PM
‎2014-08-27 03:55 PM
rob2218 wrote:Well I plan to add that option when I fix the cabinets. Its like ten minutes tops of coding
was afraid you were going to say that.....^
I hate....no wait, loathe, having to create objects in layers which are turned off JUST to accomplish something which should be programmed into the cabinet objects.
"backs" - check box for 'yes'/uncheck for 'no'.
‎2014-08-27 05:02 PM
SenecaDesignLLC wrote:rob2218 wrote:Well I plan to add that option when I fix the cabinets. Its like ten minutes tops of coding
here is a youtube link, is this what you are after?
https://www.youtube.com/watch?v=VtlfX5Z0Jww&feature=youtu.be
‎2014-08-27 05:04 PM
‎2014-08-27 05:30 PM
‎2014-08-27 05:34 PM
‎2014-08-27 05:36 PM
i added the option while i made my wife and i breakfast... so its in my library i guess ha ha. i wanted to see if it would really only take me ten minutes
‎2014-08-27 06:19 PM
well I cant really ask for money for the cabinet as it is not my property. I could however send you a detailed step by step process to add the option yourself. Its really not to difficult, and it will give you some more indepth knowledge of gdl. maybe a small paypal donation? to compensate for my wifes anger ha ha? and i guess for the time to write up the how to? Hmm...
