‎2009-01-30 07:54 PM
‎2009-01-30 09:19 PM
‎2009-01-30 09:20 PM
‎2009-01-30 09:22 PM
Aaron wrote:Actually, it's not really that, Aaron, although it may look like that. No parts are moved anyway. But, see:
If you are using ArchiCAD MEP, have a look for them in the MEP Library. The installer sucks them out of the regular library and puts them in the MEP Library.
‎2009-01-30 09:28 PM
‎2009-01-30 09:55 PM
Karl wrote:That was it. Thanks very much. [As you put it in that thread: 'disconcerting'.]
Do you have MEP, Ignacio? (Don't see it in your signature.)
If so, see:
http://archicad-talk.graphisoft.com/viewtopic.php?p=135587
‎2009-02-02 05:19 AM
Karl wrote:Then, if you have to use a non-MEP enabled dongle, you can't see them or use them at all.Aaron wrote:Actually, it's not really that, Aaron, although it may look like that. No parts are moved anyway. But, see:
when MEP is loaded, various parts are filtered into different tools. The behavior is very confusing to users indeed.
‎2009-02-08 02:28 AM
Then, if you have to use a non-MEP enabled dongle, you can't see them or use them at all.what if you relocate the mep addon out of the addon folder before starting ac ??... a pain indeed
Not good.
‎2009-02-08 06:42 PM
Rakela wrote:That's what I've done when I needed to replicate a client environment.
‎2009-02-08 11:07 PM
I always have a folder called "Add-ons Disabled"Great Idea Karl !! and thx a lot for the explanation.
