Bathroom fixtures missing in AC 12 US library?
AC 12 2420 Mactel, and library up to date. I only get the wc basin etc. 2D symbols, and don't have the models.
Maybe with the CSI sections reshuffling the bathroom fixtures models just got lost somewhere? Or am I missing something big?
11 REPLIES 11
Aaron Bourgoin
If you are using ArchiCAD MEP, have a look for them in the MEP Library. The installer sucks them out of the regular library and puts them in the MEP Library.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
Do you have MEP, Ignacio? (Don't see it in your signature.)
If so, see:
http://archicad-talk.graphisoft.com/viewtopic.php?p=135587
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
Actually, it's not really that, Aaron, although it may look like that. No parts are moved anyway. But, see:
when MEP is loaded, various parts are filtered into different tools. The behavior is very confusing to users indeed.
Aaron Bourgoin
Hey Karl,
I hadn't gone looking myself. one of my clients announced to me that his 'bog' had been moved. Thanks for the clarification.
Rhino 8 Mac
MacOS 15.2
If so, see:
That was it. Thanks very much. [As you put it in that thread: 'disconcerting'.]
Djordje
Then, if you have to use a non-MEP enabled dongle, you can't see them or use them at all.
Not good.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Rakela Raul
Not good.
what if you relocate the mep addon out of the addon folder before starting ac ??... a pain indeed
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
That's what I've done when I needed to replicate a client environment.
I always have a folder called "Add-ons Disabled" in my application folder to drag these things into, so they are easily found to drag back. The most frequent reason that I'll drag add-ons there is that many will otherwise create data in the project file resulting in prompting someone without the add-ons, upon opening the file, with the dialog with checkboxes asking if the data associated with the add-on should be saved. When creating templates for others, this is a particular hassle and easily forgotten with all of the other nitty gritty details of template creation.
Rakela Raul
Great Idea Karl !! and thx a lot for the explanation.
