Bim components library error PLEASE HELP URGENT
mi_jan
i am having trouble "downloading and embedding" various objects from the bim components library. I have tried in various locations with different internet connections. I attached a screen shot of the error message, it happens with most objects.
- i have archicad 19 student version
iMac - MacOs Big Sur 11.6.6
Archicad 24 - Latest Build
Archicad 25 - Latest Build
4 REPLIES 4
mi_jan
thanks, very helpful guys!
Katalin Borszeki
This issue is know by us already and is added to our database to be fixed as #193929.
The fix is planned to be released with the next update of ARCHICAD 19.
As a workaround till then, please try downloading more than one time, sometimes multiple attempts might work! Thanks
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
David Maudlin
I ran into this error message last week, but discovered the object in the Embedded Library anyway.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
mi_jan
Thanks for your reply.
Trying multiple times is not working for me, what I was able to do was download the objects directly from the BIMcomponents page and opening them in my objects tab.
