Board and batten siding.
Tom Krowka
Anybody have a recommendation for creating actual vertical board and batten siding, other than a picture of it to use with a material. I thought something like this might be in wall accessories, but no go. Found one on Objects Online, but for version 9. Perhaps something more current?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
26 REPLIES 26
Complex Profile???
Stress Co_
Cadimage's Accessory Tools
Marc Corney, Architect
Red Canoe Architecture, P. A.
Tom Krowka
$900.00-not ready for that kind of investment for siding. Phew! Was hoping I had already bought it, just didn't know it yet. Also, don't know how I would do it with complex profiles.
Don't want to add many many small pieces to the model, trim them, etc. Too time consuming. Thought that might have already been created as a .gsm. Found one on object online, but it only good for V9.
thanks.
Thomas@wkarchwk.com
www.walshkrowka.com
Stress Co_
I think that's the Suite price. Alone it's $199 USD
Complex Profiles would work if the siding is horizontal, but since you specified board and batten, I'm guessing it's vertical.
Dwight
Dumassduffus Workaround for Vertical battens:
Batten-shaped slab extrusions. Stick 'em on like in reality?
Cut them out for openings?
Dwight Atkinson
Or shell out 149.00 USD and get your hands on the D3 Trim+Stair collection and use the "dentil straight" object to produce your Board and Batten Siding. Then use SEOs for where you have door and window openings. See attached image for example:
Ralph Wessel
Mentor
Tom wrote:
Anybody have a recommendation for creating actual vertical board and batten siding?
Take a look at OBJECTiVE. You can create a profile object of the siding which can be easily rotated and split in 3D, and can even be placed and cut directly in a section/elevation window. SEO works fine too if required, although OBJECTiVE's Split tool will handle most requirements better (e.g. it looks right in 2D and you get snap points along the cut). You will find many other uses for the tools beyond this application too: http://www.encina.co.uk/objective.html
Ralph Wessel BArch
Active Thread Ltd
Dwight
Dear Mr. Face Paint: could you please confirm your rendering method.
Dwight Atkinson
