‎2008-03-21 07:07 PM
‎2008-03-21 07:20 PM
‎2008-03-21 07:57 PM
‎2008-03-21 08:32 PM
‎2008-03-21 08:37 PM
‎2008-03-21 09:27 PM
Tom wrote:Complex Profiles would work if the siding is horizontal, but since you specified board and batten, I'm guessing it's vertical.
Also, don't know how I would do it with complex profiles.
‎2008-03-21 11:07 PM
‎2008-03-22 01:15 AM
‎2008-03-22 01:41 AM
Tom wrote:Take a look at OBJECTiVE. You can create a profile object of the siding which can be easily rotated and split in 3D, and can even be placed and cut directly in a section/elevation window. SEO works fine too if required, although OBJECTiVE's Split tool will handle most requirements better (e.g. it looks right in 2D and you get snap points along the cut). You will find many other uses for the tools beyond this application too:
Anybody have a recommendation for creating actual vertical board and batten siding?
‎2008-03-22 01:45 AM
junior wrote:Dear Mr. Face Paint: could you please confirm your rendering method.
See attached image for example:
