Bottom Offset to Home Story
hi ACler,
i am looking for a way to refer in the field "bottom Offset to Home Story" of my Object not to the bottom but to the center of the object. I need the dimension floor finished top edge - axe of the object.
thx for help!
Florian
David Maudlin
Florian:
In the Object's 3D Script you will need to add an AddZ command with the value of 1/2 the height of the Object (whether that is a fixed value or a parameter), probably at the top of the script.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
hello David!
yes! its working!
thanks a lot!!
rdgs, Florian
David Maudlin
Florian:
Glad that worked, thanks for adding the signature.
David
