Building Material MISSING + frameless corner window
I am using an ArchiCAD 18 and I don't have a Building Material dialog box in Options > Element Attributes >. It only exist in Options > Element Attributes > Attribute Manager. I can not really work properly without it, is there an option to get it, maybe somewhere in work preferences? It is killing me. (
Also I can not create a window corner without a frame - was this option not jet available in ArchiCAD 18?
Thank you in advance,
Sasa
4 Replies 4
Eduardo Rolon
For the corner window please check that the window you are using is "Fixed" any other type needs a frame to be able to open.
The other question I cannot answer since I don't have AC18 installed.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
For the building materials dialogue it sounds like you have a custom work environment and this was removed from the menu.
Either load a 'Standard' work environment or edit your custom one and add that command back into the menu structure.
Stress Co_
Turn on the "Attributes" toolbar and you'll have a quick shortcut to get there.
Windows> Toolbars> Attributes
Marc Corney, Architect
Red Canoe Architecture, P. A.
Erwin Edel
Frameless "glass" corner connection doesn't work with all windows, as far as I recall.
There should be a repeating (ribbon?) horizontal window in the ArchiCAD library that allows for the setting. Maybe some others too. Could just be the Dutch localisation that has it locked/unavailable for others.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
