Calculation and GDL
Hi to all.
Is there a simple way to add calculation data to objects?
I know enough GDL to make the elements I need, but after a number of try studying the calculation manual I feel ... stupid. I simply don't get it.
The "Component" and "Description" scripts, reading the GDL User Manual, stay also unclear.
I need some input.
Thanks
5 REPLIES 5
Give us a simple example of what result you want to achieve and we can give you some ideas of howto achieve it.
sinceV6
Klingon wrote:
Hi to all.
I need some input.
Thanks
Do not take this as 100% accurate. This is from memory of read information and tutorial videos...
You'll want to add a menu with the related commands in the work environment if you haven't done so already.
In simple terms: (and referring to setting calc data inside objects)
If you want to use the "Component" and "Descriptor" parts in the library parts.-
You should use/create a database, that contains your descriptors and components.
Once you have that, open up your object and, for example, in components, click new: this will then give you the option to either select the database and put it the details such as code, etc. or link the item to a database entry; and depending on that, you must enter the remaining info so that the component you added has the correct values (for example, if you link "paint" then you can make it proportional to "surface A")
If you want to use the properties script.-
You can create Descriptors and Components in the Properties script using the keywords from the GDL reference manual that relates to that script (in the Non-geometric scripts part), but I'm not sure how that shows up in the object.
If you want to link properties objects.-
You can also create Properties objects (as Property subtypes), that only have Descriptors and Components and you link those to already existing library parts using the settings.
This should let you derive model quantities according to your linked data, either through the lists or component schedules.
This is a playlist that goes through this more in depth. It's in spanish though. But if you already know GDL and have a decent knowledge of AC, you can just follow visually.
https://www.youtube.com/playlist?list=PLkPRizz5C7bzVk9KrzCg3_CWLu_1yj--n
Hope that helps a bit.
Best regards.
Nader Belal
Mentor
Is there any example for the use of property script in GDL library and what would be the results when it's called ????
There is one example here:
http://gdl.graphisoft.com/gdl-docs/gdl-guide/chapter-9-non-geometric-scripts/the-properties-script/
If you go over to the GDL Forums at http://gdl.graphisoft.com/forums/ they may be able to help you faster. GDL questions seem to migrate over there nowadays as that's where the Graphisoft GDL developers are, answering questions.
Nader Belal
Mentor
Thank you
