2018-04-07 07:13 PM
2018-04-08 01:47 AM
2018-04-08 08:17 AM
poco2013 wrote:Thanks for the answer poco2013
Not sure I understand your question entirely --- BUT
You already have the parameters of Area and Area2 within you object. Assuming that you complete those calculations, as appropriate, then, within a schedule you would just select the library part field and under that, select your object which would then list all your parameters for that library object. Add the appropriate parameters (areas) to the schedule fields and do a sum of that field if needed.
Is there something else?
2018-04-08 06:06 PM
Laurits wrote:You may want to explain further as the summary of areas is somewhat routine. Can you further elaborate so that someone else might understand the problem and offer help?
how many square meters it's separated by Plates # 1 and 2 in this case. --????
Laurits
2018-04-10 01:04 PM
poco2013 wrote:As you can see from the drawing, I have 3 types of elements 1:40, 1:60 and 1: 100 angles on top of the plates.Laurits wrote:You may want to explain further as the summary of areas is somewhat routine. Can you further elaborate so that someone else might understand the problem and offer help?
Laurits
2018-04-12 12:20 PM
2018-04-15 10:52 AM
2018-04-16 05:56 PM
2018-04-17 08:55 AM
2018-04-17 04:01 PM
