Hello, I want to edit an existing object, I used a corner base cabinet which consists of 1 draw and a cupboard. I cant change the quantity of draws in the settings parameters etc and wondered please if there is any way I can edit the object? If possible I need for the changes to reflect in the 3d perspective. Thank you, any help or suggestions would be appreciated!!
If there is no parameter for it then you would have to select the Object and Open it for editing.
But you would have to know GDL quite well to be able to modify the script to do what you want.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
