We value your input!
Can Zones be made to write in Superscript?
I want Zones to display room area in square meters, using the shorter version of it : m2, with "2" in superscript. I also want it to be displayed in cyrillic - small cyrillic "m" is like capital latin "M".
Zone stamp is Zone_Stamp_02 10 on AC10.
Can you share any ideas?
23 REPLIES 23
Kliment,
This one is parametric. You can change Unit String (LowerCase / UpperCase) and Unit Digit (Normal / SuperScript).
Based on Zone_Stamp_02 11 (INT), which is better scripted than version 10.
Works for AC 8 to 11.
Djordje
laszlonagy wrote:
I tried Olivier's object.
Here is the result I got.
Weird, maybe it is my system.
It is an English XP SP2, but some of the settings are Hungarian regional settings. Could this be related?
Maybe you have the support for the right-to-left languages installed?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I checked it but no, no such support is installed on my system.
The strange thing is that New & Reset solved it and now it works correctly.
IMO the Oliviers improvements to the zone stamp should be added to the next AC object library...
Now this is a parametric zone stamp!
Thanks Olivier.
