‎2025-01-16 01:46 AM - last edited on ‎2025-01-16 01:49 AM by Barry Kelly
Hi there
I cant seem to edit the text associated with the AUS Window & door marker assigned to each window and door. Its displaying in layout space but for example i want to remove the (obsc) text but cant find anywhere in the window door options where you can
‎2025-01-16 02:46 AM
If you go to place a new window, is the Dimension Marker tab available? Maybe some interaction with CI Tools is hiding the default marker settings? Or some odd relation of the AC25 library being used in AC27?
‎2025-01-16 03:01 AM
Those options are probably turned off in the Work Environment settings.
‎2025-01-16 03:31 AM
Totally forgot about those options... Odd thing to have turned off. Maybe if you only work with set window sizes and types and have favourites for every combination that you do?
