2006-12-1903:55 PM - last edited on 2023-05-2412:45 PM by Rubia Torres
2006-12-1903:55 PM
Please see attached image. I have a problem with objects calling the Casement_a.gsm object. More specific W Bottom Hung 10 and W2 Tilt-Turn 10. Both on Windows and OSX.
2D floor plan symbol is ok : error messages show up in 3D and section/elevation. In certain cases ArchiCAD shuts down.
Anyone familiar with the 3D script at line 1175 (OSX) or 1167 (WIN)?
I’m using the AC libraries 10 latest update from graphisoft.
Michael wrote: And is there a quickeasy way to re-set the object to it's defaults?
Michael:
Yes. Select the object and open its dialog box. Select another object in the lower left pane, then select the original object. All the parameters will be reset to their original values, all of them, so make note of any values you want to retain from the modified object so you can reenter them.
HTH
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
