2005-03-22 01:33 AM
2005-03-22 10:37 AM
2005-03-22 02:54 PM
2005-03-23 09:22 PM
cadtek wrote:I have used plain slabs . with lights floating underneath them. Now we can use the applied vector hatch to do the grid. Locate the origin in the 3d window as desired.
A friend ask me to post the following for him -
The opinions expressed are not mine.
2005-03-23 09:49 PM
HANIEL wrote:I've had fairly good success applying the ceiling tile texture to the slab material to mimic a lay-in ceiling.cadtek wrote:I have used plain slabs . with lights floating underneath them. Now we can use the applied vector hatch to do the grid. Locate the origin in the 3d window as desired.
If you ned more realism such as coarse surface textures, you would be out of luck I believe.
2005-03-26 11:44 PM
Millard,
With regard to your image, I have several questions on the manner in which you do lay-in ceilings. Since I'm really the guy that caused this thread to be started and since you are a good ole TEXAS boy too, I don't feel so bad imposing-
1. What is the source of the texture for 2x2 grid& tiles?
2. Is same texture used for both renderings and reflected ceiling plan?
3. What is source of light fixt., Archicad library or other, what are significant settings?
4. How do you cut holes in slab for fixt. (boolean)?
Now to the wall - What texture did you use for glass block windows?
Thanks in Advance,
2005-04-01 02:32 AM
Millard wrote:Millard, assuming you mean a suspended ceiling here, how do you get it to show up properly in 3D cutaways or sections with this approach? It's all well and good for it to look nice in a rendering like this, but one needs to be able to see the space in sections and so on.
2005-04-01 05:35 AM
1. What is the source of the texture for 2x2 grid& tiles?It is a 3rd party texture from a library in our office. I'm not sure of the original source of the library. It's named TL_66 Ceiling Tile
2. Is same texture used for both renderings and reflected ceiling plan?No, the texture is just used in the renderings. For the ceiling plan I applied a fill to the ceiling slab to show the ceiling grid.
3. What is source of light fixt., Archicad library or other, what are significant settings?The light fixture is the Archicad Fluorescent Recessed 01. I'm not in the office, but I believe the settings were the default. I did have to check "use the object's materials. Also I may have increased the light intensity.
4. How do you cut holes in slab for fixt. (boolean)?I set the light fixtures slightly below the ceiling plane and they show in the rendering this way.
Now to the wall - What texture did you use for glass block windows?The window is theW Glass Block Wall with Glass Block1 for the glass texture. I had to size the texture to the size of the blocks in the window.
2005-04-01 05:42 AM
Wendy wrote:This was just a schematic rendering to sell the space to the Owner, so no sections or construction drawings yet. Actually for those I generally embellish the sections with 2D to show the lay-in ceiling detail.Millard wrote:Millard, assuming you mean a suspended ceiling here, how do you get it to show up properly in 3D cutaways or sections with this approach? It's all well and good for it to look nice in a rendering like this, but one needs to be able to see the space in sections and so on.
Wendy
2005-06-16 02:11 AM
