‎2012-11-28 03:33 AM
‎2012-11-28 03:34 AM
‎2012-11-28 04:03 AM
‎2012-11-28 04:17 PM
‎2012-11-28 04:18 PM
‎2012-11-28 09:17 PM
lec1212 wrote:Almost sure, you left something there. If the GDL interpreter finds anything "readable" in the 2D Script, will try to use it instead of the 2D Drawing.
I've tried ! commenting out all the lines in the 2D script which makes the stock 2D floor plan view go away, but my 2d symbol does not show.
lec1212 wrote:
So I looked in the GDL reference guide and found the Fragment2 command.
However in trying what I thought were all the variations shown, I kept getting errors when I did a check script.
‎2012-11-29 02:33 AM
rocorona wrote:lec1212 wrote:Almost sure, you left something there. If the GDL interpreter finds anything "readable" in the 2D Script, will try to use it instead of the 2D Drawing.
‎2012-11-29 02:36 AM
lec1212 wrote:oooppsss re. p13rocorona wrote:lec1212 wrote:Almost sure, you left something there. If the GDL interpreter finds anything "readable" in the 2D Script, will try to use it instead of the 2D Drawing.
I had looked up and down the 2D script 3 times only not ! commenting out lines that were blank, but must have missed something I guess.
You copyied the command as it is on the manual, but you didn't read the "CONVENTIONS USED IN THIS BOOK" paragraph (p.13). You must write as in syntax only the words in capital letters. Generally, the others are to be substituted by values (or variables)
So use:
FRAGMENT2 ALL, 0
or
FRAGMENT2 ALL, 1
(with the first one the drawn elements retain their attributes, with the second one the current attributes of the object will be used)
In the other your post the error is generated by the comma between "FRAGMENT2" and "ALL"
To stop the interpreter after it executes the FRAGMENT2 command, add a row with the END command, or simply delete all.
‎2012-11-29 01:51 PM
lec1212 wrote:An easier way to do this is to select the Script Window, then command Select All, then command Comment (this command is in the Edit menu when editing a library part).rocorona wrote:lec1212 wrote:Almost sure, you left something there. If the GDL interpreter finds anything "readable" in the 2D Script, will try to use it instead of the 2D Drawing.
‎2012-11-29 03:44 PM
