Bruce
Circular hole in circular PRISM
Can someone enlighten me on the trick to create a circular hole in a circular PRISM? The usual -1 status code doesn't seem to work.
E.g., by my reading of the GDL reference guide (page 27 for AC21) the code should be:
PRISM_ 5, height,
 0, 0, 913,
radius_outer, 360, 4000,
0, 0, -1,
radius_inner,  360, 4000,
radius_inner,  360, -1
OR
PRISM_ 6, height,
 0, 0, 913,
0, 0, -1,
0, 0, 913,
0, 0, -1
But both of these return a compiling error.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
1 Solution
Try this.
I think the problem is you are needing to use the circle centre with the -1 mask which dosen't work with a full 360 degree circle.
Break it up into semi circles.
	PRISM_ 14, height,
		radius_outer,       0.0,      15+64,
		0,       0.0,    900,
		   0,          180,   4000,
	   -radius_outer,       0.0,      15+64,
		0,       0.0,    900,
		   0,          180,   4000,
		radius_outer,       0.0,     -1,
		radius_inner,       0.0,      15+64,
		0,       0.0,    900,
		   0,          180,   4000,
	   -radius_inner,       0.0,      15+64,
		0,       0.0,    900,
		   0,          180,   4000,
		radius_inner,       0.0,     -1
Go to post
4 Replies 4
Try this.
	PRISM_ 14, height,
		0,       0.0,    900,
		   0,          180,   4000,
		0,       0.0,    900,
		   0,          180,   4000,
		0,       0.0,    900,
		   0,          180,   4000,
		0,       0.0,    900,
		   0,          180,   4000,
Bruce
That's it Barry - thanks.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Jochen Suehlo
Although logically it should not, the following simplified version works as well:
PRISM_ 3, 1,
0, 0,  979,
0.2, 360, 4079,
0.1, 360, 4049
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
Bruce
I like that one too!
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
