adrianasofiasm_
How can I make a vertical hole in mesh?
Hi there! How can I create a vertical, circular hole in a mesh with a width of 5'-11"? I can only seem to be able to draw holes in plan view, which means they're horizontal and parallel to the floor. I want to make a hole to make a tunnel-like entrance.
I tried windows but they can only be placed on walls and I can't seem to adjust the width of walls either.
Thanks
AC28 USA - MacBook Pro 14" - Apple M1 Pro - 16 GB
4 Replies 4
Steve Jepson
SEO.  Solid Element Operations.
I don't think you worded your question correctly.
How can I create a vertical, circular hole in a mesh with a width of 5'-11"?     and   "I want to make a hole to make a tunnel-like entrance."   don't seem like the same thing.  I don't think that would be called a vertical hole.
In any case, you can make a hole at any angle in a mesh using SEO and the Cylinder object from the Basic Shapes folder in the library.
adrianasofiasm_
I've tried that, but after the subtraction, the mesh stays solid, there is no hole.
adrianasofiasm_
Did you put the operator in a separate layer so you can turn that layer off?
