2023-10-24 11:01 PM
Hi there! How can I create a vertical, circular hole in a mesh with a width of 5'-11"? I can only seem to be able to draw holes in plan view, which means they're horizontal and parallel to the floor. I want to make a hole to make a tunnel-like entrance.
I tried windows but they can only be placed on walls and I can't seem to adjust the width of walls either.
Thanks
2023-10-25 08:54 PM - edited 2023-10-26 02:54 AM
SEO. Solid Element Operations.
I don't think you worded your question correctly.
How can I create a vertical, circular hole in a mesh with a width of 5'-11"? and "I want to make a hole to make a tunnel-like entrance." don't seem like the same thing. I don't think that would be called a vertical hole.
In any case, you can make a hole at any angle in a mesh using SEO and the Cylinder object from the Basic Shapes folder in the library.
2023-10-27 07:00 PM
I've tried that, but after the subtraction, the mesh stays solid, there is no hole.
2023-10-27 07:05 PM
2023-10-28 10:11 AM
Did you put the operator in a separate layer so you can turn that layer off?
