Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Coiling Door
I was wondering if anyone has or knows how to get a coiling overhead door.
3 REPLIES 3
Erika Epstein
You could try objectsonline
http://www.objectsonline.com/customer/search.php?substring=garage
or modify one of the garage doors in the AC library.
How accurate does it need to be?
Will creating a custom door panel that looks like what you want suffice?
Will adding a dummy piece above it to look like the housing suffice?
These are relatively simple to achieve. If you aren't sure how, ask with a description of what the roll-up door should look like.
Does is need to work in a movie? If this last, ask on the forum for some help or a GDL expert who could make one for you.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks Erika. I just thought there would be one made somewhere. I think adding a dummy piece will be enough.
I appreciate the response.
Erika Epstein
There ought to be; I've often wanted one myself.
Perhaps now someone out there will be inspired to create one
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
